Time Before: 0.01829 seconds
Time After: 0.02450 seconds
Time Taken: 0.00621 seconds
Time Before: 0.02458 seconds
Time After: 0.02499 seconds
Time Before: 0.02528 seconds
Time After: 0.02545 seconds
Time Before: 0.02629 seconds
Time After: 0.02842 seconds
Time Taken: 0.00213 seconds
Time Before: 0.02553 seconds
Time After: 0.03266 seconds
Time Taken: 0.00713 seconds
Time Before: 0.03976 seconds
Time After: 0.04013 seconds
Time Before: 0.04266 seconds
Time After: 0.04386 seconds
Time Before: 0.03906 seconds
Time After: 0.04416 seconds
Time Taken: 0.00510 seconds
Time Before: 0.08162 seconds
Time After: 0.08176 seconds
Time Before: 0.09515 seconds
Time After: 0.09642 seconds
Time Before: 0.10923 seconds
Time After: 0.10938 seconds
Time Before: 0.11196 seconds
Time After: 0.11344 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101259' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.12999 seconds
Time After: 0.13029 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
