Time Before: 0.00142 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00246 seconds
Time Before: 0.00276 seconds
Time After: 0.00291 seconds
Time Before: 0.00380 seconds
Time After: 0.00641 seconds
Time Taken: 0.00261 seconds
Time Before: 0.00300 seconds
Time After: 0.00983 seconds
Time Taken: 0.00684 seconds
Time Before: 0.01175 seconds
Time After: 0.01226 seconds
Time Before: 0.01525 seconds
Time After: 0.01648 seconds
Time Before: 0.01113 seconds
Time After: 0.01666 seconds
Time Taken: 0.00553 seconds
Time Before: 0.02225 seconds
Time After: 0.02251 seconds
Time Before: 0.02447 seconds
Time After: 0.02574 seconds
Time Before: 0.02881 seconds
Time After: 0.02896 seconds
Time Before: 0.03103 seconds
Time After: 0.03247 seconds
UPDATE session SET lastactivity = 1785316354, location = '/forums/private.php?do=newpm&explain=1&u=101266' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04491 seconds
Time After: 0.04522 seconds
