Time Before: 0.01546 seconds
Time After: 0.02060 seconds
Time Taken: 0.00513 seconds
Time Before: 0.02068 seconds
Time After: 0.02113 seconds
Time Before: 0.02135 seconds
Time After: 0.02149 seconds
Time Before: 0.02222 seconds
Time After: 0.02490 seconds
Time Taken: 0.00268 seconds
Time Before: 0.02156 seconds
Time After: 0.02899 seconds
Time Taken: 0.00744 seconds
Time Before: 0.03538 seconds
Time After: 0.03584 seconds
Time Before: 0.03725 seconds
Time After: 0.03852 seconds
Time Before: 0.03467 seconds
Time After: 0.03876 seconds
Time Taken: 0.00410 seconds
Time Before: 0.05819 seconds
Time After: 0.05844 seconds
Time Before: 0.07512 seconds
Time After: 0.07634 seconds
Time Before: 0.08766 seconds
Time After: 0.08784 seconds
Time Before: 0.09040 seconds
Time After: 0.09196 seconds
Time Taken: 0.00155 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101272' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.11417 seconds
Time After: 0.11456 seconds
