Time Before: 0.02155 seconds
Time After: 0.02895 seconds
Time Taken: 0.00740 seconds
Time Before: 0.02904 seconds
Time After: 0.03002 seconds
Time Taken: 0.00098 seconds
Time Before: 0.03030 seconds
Time After: 0.03048 seconds
Time Before: 0.03141 seconds
Time After: 0.03356 seconds
Time Taken: 0.00215 seconds
Time Before: 0.03054 seconds
Time After: 0.03758 seconds
Time Taken: 0.00704 seconds
Time Before: 0.04486 seconds
Time After: 0.04527 seconds
Time Before: 0.04783 seconds
Time After: 0.04904 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04420 seconds
Time After: 0.04924 seconds
Time Taken: 0.00504 seconds
Memory After: 2,261.820 KB
Time Before: 0.07529 seconds
Time After: 0.07546 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.09613 seconds
Time After: 0.09738 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.10831 seconds
Time After: 0.10848 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.11116 seconds
Time After: 0.11312 seconds
Time Taken: 0.00196 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789040307, location = '/forums/private.php?do=newpm&explain=1&u=101288' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.13153 seconds
Time After: 0.13218 seconds
Time Taken: 0.00065 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
