Time Before: 0.02144 seconds
Time After: 0.03219 seconds
Time Taken: 0.01075 seconds
Time Before: 0.03231 seconds
Time After: 0.03272 seconds
Time Before: 0.03294 seconds
Time After: 0.03311 seconds
Time Before: 0.03386 seconds
Time After: 0.03609 seconds
Time Taken: 0.00223 seconds
Time Before: 0.03318 seconds
Time After: 0.04007 seconds
Time Taken: 0.00690 seconds
Time Before: 0.05333 seconds
Time After: 0.05376 seconds
Time Before: 0.05681 seconds
Time After: 0.05804 seconds
Time Before: 0.05268 seconds
Time After: 0.05824 seconds
Time Taken: 0.00556 seconds
Time Before: 0.09743 seconds
Time After: 0.09758 seconds
Time Before: 0.12492 seconds
Time After: 0.12623 seconds
Time Before: 0.13631 seconds
Time After: 0.13646 seconds
Time Before: 0.13914 seconds
Time After: 0.14062 seconds
UPDATE session SET lastactivity = 1785421308, location = '/forums/private.php?do=newpm&explain=1&u=10129', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.16005 seconds
Time After: 0.16036 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
