Time Before: 0.00156 seconds
Time After: 0.00207 seconds
Time Before: 0.00218 seconds
Time After: 0.00297 seconds
Time Taken: 0.00079 seconds
Time Before: 0.00333 seconds
Time After: 0.00352 seconds
Time Before: 0.00446 seconds
Time After: 0.00721 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00361 seconds
Time After: 0.01180 seconds
Time Taken: 0.00819 seconds
Time Before: 0.01373 seconds
Time After: 0.01421 seconds
Time Before: 0.01745 seconds
Time After: 0.01864 seconds
Time Before: 0.01299 seconds
Time After: 0.01887 seconds
Time Taken: 0.00588 seconds
Time Before: 0.02584 seconds
Time After: 0.02602 seconds
Time Before: 0.02800 seconds
Time After: 0.02926 seconds
End call of global.php: 0.032081127166748
Time Before: 0.03378 seconds
Time After: 0.03398 seconds
Time Before: 0.03699 seconds
Time After: 0.03847 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=101302', badlocation = 1
Time Before: 0.05103 seconds
Time After: 0.05137 seconds
Page generated in 0.050113201141357 seconds with 9 queries, spending 0.0088691711425781 doing MySQL queries and 0.041244029998779 doing PHP things.
