Time Before: 0.02225 seconds
Time After: 0.02851 seconds
Time Taken: 0.00626 seconds
Time Before: 0.02859 seconds
Time After: 0.02914 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02940 seconds
Time After: 0.02960 seconds
Time Before: 0.03041 seconds
Time After: 0.03346 seconds
Time Taken: 0.00305 seconds
Time Before: 0.02967 seconds
Time After: 0.03749 seconds
Time Taken: 0.00782 seconds
Time Before: 0.04534 seconds
Time After: 0.04575 seconds
Time Before: 0.04830 seconds
Time After: 0.04953 seconds
Time Before: 0.04463 seconds
Time After: 0.04971 seconds
Time Taken: 0.00508 seconds
Time Before: 0.08920 seconds
Time After: 0.08939 seconds
Time Before: 0.10194 seconds
Time After: 0.10316 seconds
Time Before: 0.11191 seconds
Time After: 0.11212 seconds
Time Before: 0.11536 seconds
Time After: 0.11689 seconds
Time Taken: 0.00153 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101303' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.13562 seconds
Time After: 0.13594 seconds
