Time Before: 0.00171 seconds
Time After: 0.00214 seconds
Time Before: 0.00222 seconds
Time After: 0.00288 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00316 seconds
Time After: 0.00332 seconds
Time Before: 0.00408 seconds
Time After: 0.00630 seconds
Time Taken: 0.00222 seconds
Time Before: 0.00337 seconds
Time After: 0.00971 seconds
Time Taken: 0.00634 seconds
Time Before: 0.01154 seconds
Time After: 0.01182 seconds
Time Before: 0.01369 seconds
Time After: 0.01483 seconds
Time Taken: 0.00114 seconds
Time Before: 0.01098 seconds
Time After: 0.01501 seconds
Time Taken: 0.00402 seconds
Time Before: 0.01980 seconds
Time After: 0.01989 seconds
Time Taken: 0.00009 seconds
Time Before: 0.02150 seconds
Time After: 0.02272 seconds
End call of global.php: 0.024308919906616
Time Before: 0.02546 seconds
Time After: 0.02562 seconds
Time Before: 0.02758 seconds
Time After: 0.02904 seconds
SET lastactivity = 1788872789, location = '/forums/private.php?do=newpm&explain=1&u=101310'
Time Before: 0.04263 seconds
Time After: 0.04320 seconds
Time Taken: 0.00056 seconds
Page generated in 0.041626930236816 seconds with 9 queries, spending 0.0079748630523682 doing MySQL queries and 0.033652067184448 doing PHP things.
