Time Before: 0.00152 seconds
Time After: 0.00204 seconds
Time Before: 0.00211 seconds
Time After: 0.00248 seconds
Time Before: 0.00272 seconds
Time After: 0.00288 seconds
Time Before: 0.00356 seconds
Time After: 0.00588 seconds
Time Taken: 0.00232 seconds
Time Before: 0.00293 seconds
Time After: 0.00946 seconds
Time Taken: 0.00653 seconds
Time Before: 0.01119 seconds
Time After: 0.01156 seconds
Time Before: 0.01430 seconds
Time After: 0.01546 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01063 seconds
Time After: 0.01573 seconds
Time Taken: 0.00510 seconds
Time Before: 0.02234 seconds
Time After: 0.02281 seconds
Time Before: 0.02494 seconds
Time After: 0.02615 seconds
End call of global.php: 0.027906179428101
Time Before: 0.02910 seconds
Time After: 0.02927 seconds
Time Before: 0.03158 seconds
Time After: 0.03311 seconds
Time Taken: 0.00152 seconds
SET lastactivity = 1788986494, location = '/forums/private.php?do=newpm&explain=1&u=101316', badlocation = 1
Time Before: 0.04611 seconds
Time After: 0.04646 seconds
Page generated in 0.045212030410767 seconds with 9 queries, spending 0.0080957412719727 doing MySQL queries and 0.037116289138794 doing PHP things.
