Time Before: 0.02456 seconds
Time After: 0.03476 seconds
Time Taken: 0.01020 seconds
Time Before: 0.03485 seconds
Time After: 0.03532 seconds
Time Before: 0.03567 seconds
Time After: 0.03591 seconds
Time Before: 0.03684 seconds
Time After: 0.03925 seconds
Time Taken: 0.00241 seconds
Time Before: 0.03599 seconds
Time After: 0.04289 seconds
Time Taken: 0.00690 seconds
Time Before: 0.05527 seconds
Time After: 0.05567 seconds
Time Before: 0.05836 seconds
Time After: 0.05955 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05385 seconds
Time After: 0.05983 seconds
Time Taken: 0.00598 seconds
Memory After: 2,261.820 KB
Time Before: 0.11553 seconds
Time After: 0.11570 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.13925 seconds
Time After: 0.14050 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.15606 seconds
Time After: 0.15665 seconds
Time Taken: 0.00059 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.15941 seconds
Time After: 0.16085 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789143119, location = '/forums/private.php?do=newpm&explain=1&u=101369', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.18137 seconds
Time After: 0.18201 seconds
Time Taken: 0.00064 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
