Time Before: 0.02181 seconds
Time After: 0.03136 seconds
Time Taken: 0.00955 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.03144 seconds
Time After: 0.03196 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03218 seconds
Time After: 0.03233 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03311 seconds
Time After: 0.03550 seconds
Time Taken: 0.00239 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03240 seconds
Time After: 0.03970 seconds
Time Taken: 0.00730 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04913 seconds
Time After: 0.04956 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.05130 seconds
Time After: 0.05251 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.04822 seconds
Time After: 0.05276 seconds
Time Taken: 0.00454 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.08257 seconds
Time After: 0.08282 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.35778 seconds
Time After: 0.35905 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.38839 seconds
Time After: 0.38853 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.39576 seconds
Time After: 0.39744 seconds
Time Taken: 0.00168 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1772862907, location = '/forums/private.php?do=newpm&explain=1&u=101373', badlocation = 1 WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.42614 seconds
Time After: 0.42643 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
