Time Before: 0.00163 seconds
Time After: 0.00218 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00225 seconds
Time After: 0.00265 seconds
Time Before: 0.00283 seconds
Time After: 0.00294 seconds
Time Before: 0.00383 seconds
Time After: 0.00841 seconds
Time Taken: 0.00458 seconds
Time Before: 0.00298 seconds
Time After: 0.01192 seconds
Time Taken: 0.00894 seconds
Time Before: 0.01411 seconds
Time After: 0.01451 seconds
Time Before: 0.01748 seconds
Time After: 0.01867 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01339 seconds
Time After: 0.01891 seconds
Time Taken: 0.00551 seconds
Memory After: 2,261.820 KB
Time Before: 0.02632 seconds
Time After: 0.02660 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02901 seconds
Time After: 0.03032 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.032014846801758
Time Before: 0.03350 seconds
Time After: 0.03367 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03626 seconds
Time After: 0.03813 seconds
Time Taken: 0.00187 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789028954, location = '/forums/private.php?do=newpm&explain=1&u=101403'
Time Before: 0.05251 seconds
Time After: 0.05279 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.051558971405029 seconds with 9 queries, spending 0.010599374771118 doing MySQL queries and 0.040959596633911 doing PHP things.
