Time Before: 0.00142 seconds
Time After: 0.00187 seconds
Time Before: 0.00194 seconds
Time After: 0.00233 seconds
Time Before: 0.00259 seconds
Time After: 0.00274 seconds
Time Before: 0.00370 seconds
Time After: 0.00660 seconds
Time Taken: 0.00291 seconds
Time Before: 0.00282 seconds
Time After: 0.01182 seconds
Time Taken: 0.00901 seconds
Time Before: 0.01402 seconds
Time After: 0.01447 seconds
Time Before: 0.01589 seconds
Time After: 0.01709 seconds
Time Before: 0.01337 seconds
Time After: 0.01735 seconds
Time Taken: 0.00399 seconds
Time Before: 0.02404 seconds
Time After: 0.02419 seconds
Time Before: 0.02615 seconds
Time After: 0.02741 seconds
Time Before: 0.03149 seconds
Time After: 0.03188 seconds
Time Before: 0.03473 seconds
Time After: 0.03616 seconds
UPDATE session SET lastactivity = 1776659346, location = '/forums/private.php?do=newpm&explain=1&u=101404' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.05310 seconds
Time After: 0.05341 seconds
