Time Before: 0.01028 seconds
Time After: 0.01323 seconds
Time Taken: 0.00295 seconds
Time Before: 0.01332 seconds
Time After: 0.01382 seconds
Time Before: 0.01402 seconds
Time After: 0.01415 seconds
Time Before: 0.01484 seconds
Time After: 0.01719 seconds
Time Taken: 0.00234 seconds
Time Before: 0.01420 seconds
Time After: 0.02128 seconds
Time Taken: 0.00708 seconds
Time Before: 0.02788 seconds
Time After: 0.02833 seconds
Time Before: 0.03086 seconds
Time After: 0.03205 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02731 seconds
Time After: 0.03226 seconds
Time Taken: 0.00495 seconds
Memory After: 2,261.820 KB
Time Before: 0.05054 seconds
Time After: 0.05069 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.06119 seconds
Time After: 0.06242 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.064338207244873
Time Before: 0.07161 seconds
Time After: 0.07179 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.07409 seconds
Time After: 0.07557 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788893354, location = '/forums/private.php?do=newpm&explain=1&u=101405'
Time Before: 0.09282 seconds
Time After: 0.09333 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.091783046722412 seconds with 9 queries, spending 0.0081570148468018 doing MySQL queries and 0.08362603187561 doing PHP things.
