Time Before: 0.02559 seconds
Time After: 0.03448 seconds
Time Taken: 0.00889 seconds
Time Before: 0.03459 seconds
Time After: 0.03506 seconds
Time Before: 0.03531 seconds
Time After: 0.03545 seconds
Time Before: 0.03621 seconds
Time After: 0.03851 seconds
Time Taken: 0.00230 seconds
Time Before: 0.03553 seconds
Time After: 0.04285 seconds
Time Taken: 0.00732 seconds
Time Before: 0.05121 seconds
Time After: 0.05174 seconds
Time Taken: 0.00054 seconds
Time Before: 0.05430 seconds
Time After: 0.05553 seconds
Time Before: 0.05055 seconds
Time After: 0.05576 seconds
Time Taken: 0.00521 seconds
Time Before: 0.08874 seconds
Time After: 0.08888 seconds
Time Before: 0.10839 seconds
Time After: 0.10969 seconds
Time Before: 0.11831 seconds
Time After: 0.11850 seconds
Time Before: 0.12085 seconds
Time After: 0.12248 seconds
Time Taken: 0.00162 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101408' WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.14152 seconds
Time After: 0.14186 seconds
