Time Before: 0.00186 seconds
Time After: 0.00297 seconds
Time Taken: 0.00111 seconds
Time Before: 0.00308 seconds
Time After: 0.00354 seconds
Time Before: 0.00380 seconds
Time After: 0.00396 seconds
Time Before: 0.00479 seconds
Time After: 0.00870 seconds
Time Taken: 0.00391 seconds
Time Before: 0.00404 seconds
Time After: 0.01393 seconds
Time Taken: 0.00988 seconds
Time Before: 0.01601 seconds
Time After: 0.01647 seconds
Time Before: 0.01905 seconds
Time After: 0.02046 seconds
Time Taken: 0.00140 seconds
Time Before: 0.01525 seconds
Time After: 0.02072 seconds
Time Taken: 0.00547 seconds
Time Before: 0.02785 seconds
Time After: 0.02813 seconds
Time Before: 0.03020 seconds
Time After: 0.03145 seconds
End call of global.php: 0.033266067504883
Time Before: 0.03439 seconds
Time After: 0.03464 seconds
Time Before: 0.03672 seconds
Time After: 0.03826 seconds
Time Taken: 0.00154 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=101414'
Time Before: 0.05130 seconds
Time After: 0.05163 seconds
Page generated in 0.050368070602417 seconds with 9 queries, spending 0.010054588317871 doing MySQL queries and 0.040313482284546 doing PHP things.
