Time Before: 0.00150 seconds
Time After: 0.00203 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00210 seconds
Time After: 0.00252 seconds
Time Before: 0.00281 seconds
Time After: 0.00298 seconds
Time Before: 0.00380 seconds
Time After: 0.00605 seconds
Time Taken: 0.00225 seconds
Time Before: 0.00303 seconds
Time After: 0.00942 seconds
Time Taken: 0.00639 seconds
Time Before: 0.01130 seconds
Time After: 0.01177 seconds
Time Before: 0.01488 seconds
Time After: 0.01610 seconds
Time Before: 0.01060 seconds
Time After: 0.01635 seconds
Time Taken: 0.00575 seconds
Time Before: 0.02284 seconds
Time After: 0.02300 seconds
Time Before: 0.02498 seconds
Time After: 0.02622 seconds
Time Before: 0.03049 seconds
Time After: 0.03066 seconds
Time Before: 0.03365 seconds
Time After: 0.03511 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101430' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04945 seconds
Time After: 0.04984 seconds
