Time Before: 0.00146 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00245 seconds
Time Before: 0.00269 seconds
Time After: 0.00281 seconds
Time Before: 0.00343 seconds
Time After: 0.00573 seconds
Time Taken: 0.00230 seconds
Time Before: 0.00286 seconds
Time After: 0.00942 seconds
Time Taken: 0.00656 seconds
Time Before: 0.01127 seconds
Time After: 0.01160 seconds
Time Before: 0.01366 seconds
Time After: 0.01491 seconds
Time Before: 0.01070 seconds
Time After: 0.01513 seconds
Time Taken: 0.00443 seconds
Time Before: 0.02036 seconds
Time After: 0.02050 seconds
Time Before: 0.22208 seconds
Time After: 0.22340 seconds
Time Taken: 0.00132 seconds
Time Before: 0.22682 seconds
Time After: 0.22702 seconds
Time Before: 0.22927 seconds
Time After: 0.23077 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1788982143, location = '/forums/private.php?do=newpm&explain=1&u=101442', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.24372 seconds
Time After: 0.24397 seconds
