Time Before: 0.00558 seconds
Time After: 0.00693 seconds
Time Taken: 0.00135 seconds
Time Before: 0.00703 seconds
Time After: 0.00756 seconds
Time Before: 0.00804 seconds
Time After: 0.00817 seconds
Time Before: 0.00912 seconds
Time After: 0.01204 seconds
Time Taken: 0.00292 seconds
Time Before: 0.00825 seconds
Time After: 0.01690 seconds
Time Taken: 0.00865 seconds
Time Before: 0.02668 seconds
Time After: 0.03121 seconds
Time Taken: 0.00453 seconds
Time Before: 0.03735 seconds
Time After: 0.05197 seconds
Time Taken: 0.01462 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02248 seconds
Time After: 0.05220 seconds
Time Taken: 0.02972 seconds
Memory After: 2,261.820 KB
Time Before: 0.07598 seconds
Time After: 0.07868 seconds
Time Taken: 0.00270 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.33277 seconds
Time After: 0.33416 seconds
Time Taken: 0.00139 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.33888 seconds
Time After: 0.33905 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.34141 seconds
Time After: 0.34549 seconds
Time Taken: 0.00408 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788992226, location = '/forums/private.php?do=newpm&explain=1&u=101448', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.36446 seconds
Time After: 0.36492 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
