Time Before: 0.00613 seconds
Time After: 0.00904 seconds
Time Taken: 0.00291 seconds
Time Before: 0.00912 seconds
Time After: 0.00949 seconds
Time Before: 0.00974 seconds
Time After: 0.00984 seconds
Time Taken: 0.00010 seconds
Time Before: 0.01049 seconds
Time After: 0.01359 seconds
Time Taken: 0.00310 seconds
Time Before: 0.00992 seconds
Time After: 0.01874 seconds
Time Taken: 0.00882 seconds
Time Before: 0.02327 seconds
Time After: 0.02355 seconds
Time Before: 0.02553 seconds
Time After: 0.02669 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02258 seconds
Time After: 0.02692 seconds
Time Taken: 0.00434 seconds
Memory After: 2,261.703 KB
Time Before: 0.04270 seconds
Time After: 0.04284 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 1.61463 seconds
Time After: 1.61629 seconds
Time Taken: 0.00166 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 1.62837 seconds
Time After: 1.62865 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 1.63123 seconds
Time After: 1.63272 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101457', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 1.65387 seconds
Time After: 1.65410 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
