Time Before: 0.00233 seconds
Time After: 0.00301 seconds
Time Taken: 0.00068 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00312 seconds
Time After: 0.00362 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00410 seconds
Time After: 0.00423 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00521 seconds
Time After: 0.00767 seconds
Time Taken: 0.00247 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00431 seconds
Time After: 0.01110 seconds
Time Taken: 0.00679 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01305 seconds
Time After: 0.01325 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01617 seconds
Time After: 0.01732 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.01244 seconds
Time After: 0.01757 seconds
Time Taken: 0.00513 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.02398 seconds
Time After: 0.02431 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.02664 seconds
Time After: 0.02789 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
End call of global.php: 0.029807806015015
Time Before: 0.03131 seconds
Time After: 0.03147 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.03361 seconds
Time After: 0.03505 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=101459'
Time Before: 0.04783 seconds
Time After: 0.04806 seconds
Memory Before: 4,918.398 KB
Memory After: 4,918.641 KB
Page generated in 0.046939849853516 seconds with 9 queries, spending 0.0078754425048828 doing MySQL queries and 0.039064407348633 doing PHP things.
