Time Before: 0.00200 seconds
Time After: 0.00264 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00274 seconds
Time After: 0.00314 seconds
Time Before: 0.00336 seconds
Time After: 0.00347 seconds
Time Before: 0.00424 seconds
Time After: 0.00739 seconds
Time Taken: 0.00315 seconds
Time Before: 0.00352 seconds
Time After: 0.01074 seconds
Time Taken: 0.00722 seconds
Time Before: 0.01273 seconds
Time After: 0.01312 seconds
Time Before: 0.01468 seconds
Time After: 0.01629 seconds
Time Taken: 0.00161 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01212 seconds
Time After: 0.01646 seconds
Time Taken: 0.00434 seconds
Memory After: 2,261.703 KB
Time Before: 0.02217 seconds
Time After: 0.02230 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02462 seconds
Time After: 0.02590 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.02862 seconds
Time After: 0.02879 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03072 seconds
Time After: 0.03218 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101475', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04430 seconds
Time After: 0.04457 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
