Time Before: 0.00866 seconds
Time After: 0.01198 seconds
Time Taken: 0.00331 seconds
Time Before: 0.01205 seconds
Time After: 0.01255 seconds
Time Before: 0.01279 seconds
Time After: 0.01296 seconds
Time Before: 0.01375 seconds
Time After: 0.01585 seconds
Time Taken: 0.00210 seconds
Time Before: 0.01303 seconds
Time After: 0.02076 seconds
Time Taken: 0.00773 seconds
Time Before: 0.02532 seconds
Time After: 0.02565 seconds
Time Before: 0.02811 seconds
Time After: 0.02966 seconds
Time Taken: 0.00154 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02458 seconds
Time After: 0.02994 seconds
Time Taken: 0.00536 seconds
Memory After: 2,261.820 KB
Time Before: 0.04677 seconds
Time After: 0.04693 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.05802 seconds
Time After: 0.05925 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.06764 seconds
Time After: 0.06781 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.07064 seconds
Time After: 0.07212 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789061631, location = '/forums/private.php?do=newpm&explain=1&u=101490' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.09063 seconds
Time After: 0.09087 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
