Time Before: 0.00276 seconds
Time After: 0.00403 seconds
Time Before: 0.00412 seconds
Time After: 0.00481 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00510 seconds
Time After: 0.00529 seconds
Time Before: 0.00606 seconds
Time After: 0.00875 seconds
Time Taken: 0.00269 seconds
Time Before: 0.00534 seconds
Time After: 0.01298 seconds
Time Taken: 0.00763 seconds
Time Before: 0.01548 seconds
Time After: 0.01593 seconds
Time Before: 0.01835 seconds
Time After: 0.01956 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01482 seconds
Time After: 0.01979 seconds
Time Taken: 0.00497 seconds
Memory After: 2,261.703 KB
Time Before: 0.02658 seconds
Time After: 0.02671 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02929 seconds
Time After: 0.03053 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.03416 seconds
Time After: 0.03432 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03643 seconds
Time After: 0.03787 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101496' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.05040 seconds
Time After: 0.05069 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
