Time Before: 0.03104 seconds
Time After: 0.04838 seconds
Time Taken: 0.01734 seconds
Time Before: 0.04847 seconds
Time After: 0.04889 seconds
Time Before: 0.04916 seconds
Time After: 0.04934 seconds
Time Before: 0.05001 seconds
Time After: 0.05245 seconds
Time Taken: 0.00244 seconds
Time Before: 0.04940 seconds
Time After: 0.05639 seconds
Time Taken: 0.00698 seconds
Time Before: 0.07106 seconds
Time After: 0.07164 seconds
Time Taken: 0.00058 seconds
Time Before: 0.07418 seconds
Time After: 0.07542 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.07043 seconds
Time After: 0.07562 seconds
Time Taken: 0.00519 seconds
Memory After: 2,261.820 KB
Time Before: 0.11804 seconds
Time After: 0.11819 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.14792 seconds
Time After: 0.14916 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.16524 seconds
Time After: 0.16542 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.16848 seconds
Time After: 0.16998 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789145425, location = '/forums/private.php?do=newpm&explain=1&u=101497' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.19167 seconds
Time After: 0.19200 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
