Time Before: 0.00687 seconds
Time After: 0.00862 seconds
Time Taken: 0.00176 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00871 seconds
Time After: 0.00929 seconds
Time Taken: 0.00058 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00957 seconds
Time After: 0.00985 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.01065 seconds
Time After: 0.01369 seconds
Time Taken: 0.00304 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00991 seconds
Time After: 0.01973 seconds
Time Taken: 0.00981 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.02425 seconds
Time After: 0.02486 seconds
Time Taken: 0.00061 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.02755 seconds
Time After: 0.02876 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.02337 seconds
Time After: 0.02897 seconds
Time Taken: 0.00560 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.04279 seconds
Time After: 0.04298 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.06245 seconds
Time After: 0.06370 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.07541 seconds
Time After: 0.07556 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.07877 seconds
Time After: 0.08032 seconds
Time Taken: 0.00155 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1773121066, location = '/forums/private.php?do=newpm&explain=1&u=101502' WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.09700 seconds
Time After: 0.09728 seconds
Memory Before: 5,997.945 KB
Memory After: 5,998.164 KB
