Time Before: 0.00475 seconds
Time After: 0.00541 seconds
Time Taken: 0.00066 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00552 seconds
Time After: 0.00590 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00614 seconds
Time After: 0.00626 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00721 seconds
Time After: 0.01012 seconds
Time Taken: 0.00291 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00636 seconds
Time After: 0.01524 seconds
Time Taken: 0.00888 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01771 seconds
Time After: 0.01810 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.02077 seconds
Time After: 0.02207 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01700 seconds
Time After: 0.02232 seconds
Time Taken: 0.00532 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.03196 seconds
Time After: 0.03208 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.04255 seconds
Time After: 0.04380 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.05454 seconds
Time After: 0.05468 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.05802 seconds
Time After: 0.05948 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101505', badlocation = 1 WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.07601 seconds
Time After: 0.07634 seconds
Memory Before: 5,997.836 KB
Memory After: 5,998.055 KB
