Time Before: 0.00139 seconds
Time After: 0.00189 seconds
Time Before: 0.00195 seconds
Time After: 0.00259 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00287 seconds
Time After: 0.00305 seconds
Time Before: 0.00390 seconds
Time After: 0.00678 seconds
Time Taken: 0.00289 seconds
Time Before: 0.00312 seconds
Time After: 0.01170 seconds
Time Taken: 0.00858 seconds
Time Before: 0.01359 seconds
Time After: 0.01396 seconds
Time Before: 0.01686 seconds
Time After: 0.01826 seconds
Time Taken: 0.00140 seconds
Time Before: 0.01303 seconds
Time After: 0.01851 seconds
Time Taken: 0.00548 seconds
Time Before: 0.02561 seconds
Time After: 0.02578 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"15.11,\";s:9:\"lastcheck\";i:1789037121;}', 1)Time Before: 0.03191 seconds
Time After: 0.03279 seconds
Time Taken: 0.00088 seconds
Memory Before: 3,439.656 KB
Memory After: 3,439.906 KB
Memory Used: 0.250 KB
Time Before: 0.03516 seconds
Time After: 0.03650 seconds
Time Taken: 0.00134 seconds
Memory Before: 3,526.469 KB
Memory After: 3,527.063 KB
Time Before: 0.04126 seconds
Time After: 0.04143 seconds
Memory Before: 4,164.406 KB
Memory After: 4,164.836 KB
Time Before: 0.04362 seconds
Time After: 0.04505 seconds
Memory Before: 4,446.055 KB
Memory After: 4,447.742 KB
UPDATE session SET lastactivity = 1789037121, location = '/forums/private.php?do=newpm&explain=1&u=101511', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05867 seconds
Time After: 0.05902 seconds
Memory Before: 4,920.063 KB
Memory After: 4,920.273 KB
