Time Before: 0.01004 seconds
Time After: 0.01309 seconds
Time Taken: 0.00306 seconds
Time Before: 0.01316 seconds
Time After: 0.01367 seconds
Time Before: 0.01386 seconds
Time After: 0.01400 seconds
Time Before: 0.01464 seconds
Time After: 0.01667 seconds
Time Taken: 0.00203 seconds
Time Before: 0.01405 seconds
Time After: 0.02080 seconds
Time Taken: 0.00675 seconds
Time Before: 0.02634 seconds
Time After: 0.02654 seconds
Time Before: 0.02931 seconds
Time After: 0.03053 seconds
Time Before: 0.02560 seconds
Time After: 0.03071 seconds
Time Taken: 0.00511 seconds
Time Before: 0.04471 seconds
Time After: 0.04487 seconds
Time Before: 0.34004 seconds
Time After: 0.34139 seconds
Time Taken: 0.00135 seconds
Time Before: 0.35161 seconds
Time After: 0.35178 seconds
Time Before: 0.35422 seconds
Time After: 0.35567 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101512', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.37336 seconds
Time After: 0.37359 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
