Time Before: 0.01106 seconds
Time After: 0.01616 seconds
Time Taken: 0.00510 seconds
Time Before: 0.01626 seconds
Time After: 0.01670 seconds
Time Before: 0.01693 seconds
Time After: 0.01705 seconds
Time Before: 0.01797 seconds
Time After: 0.02054 seconds
Time Taken: 0.00257 seconds
Time Before: 0.01712 seconds
Time After: 0.02488 seconds
Time Taken: 0.00776 seconds
Time Before: 0.03185 seconds
Time After: 0.03234 seconds
Time Before: 0.03405 seconds
Time After: 0.03529 seconds
Time Before: 0.03104 seconds
Time After: 0.03553 seconds
Time Taken: 0.00449 seconds
Time Before: 0.05632 seconds
Time After: 0.05646 seconds
Time Before: 0.06770 seconds
Time After: 0.06895 seconds
End call of global.php: 0.071271896362305
Time Before: 0.07758 seconds
Time After: 0.07775 seconds
Time Before: 0.08031 seconds
Time After: 0.08178 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=101524', badlocation = 1
Time Before: 0.10017 seconds
Time After: 0.10049 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.099046945571899 seconds with 9 queries, spending 0.0082104206085205 doing MySQL queries and 0.090836524963379 doing PHP things.
