Time Before: 0.00168 seconds
Time After: 0.00222 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00229 seconds
Time After: 0.00273 seconds
Time Before: 0.00305 seconds
Time After: 0.00317 seconds
Time Before: 0.00396 seconds
Time After: 0.00646 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00322 seconds
Time After: 0.00990 seconds
Time Taken: 0.00668 seconds
Time Before: 0.01302 seconds
Time After: 0.01352 seconds
Time Before: 0.01692 seconds
Time After: 0.01816 seconds
Time Before: 0.01220 seconds
Time After: 0.01833 seconds
Time Taken: 0.00613 seconds
Time Before: 0.02338 seconds
Time After: 0.02355 seconds
Time Before: 0.02561 seconds
Time After: 0.02686 seconds
End call of global.php: 0.028987169265747
Time Before: 0.03041 seconds
Time After: 0.03063 seconds
Time Before: 0.03277 seconds
Time After: 0.03421 seconds
SET lastactivity = 1788962665, location = '/forums/private.php?do=newpm&explain=1&u=101525', badlocation = 1
Time Before: 0.04662 seconds
Time After: 0.04696 seconds
Page generated in 0.045716047286987 seconds with 9 queries, spending 0.0082108974456787 doing MySQL queries and 0.037505149841309 doing PHP things.
