Time Before: 0.02600 seconds
Time After: 0.03314 seconds
Time Taken: 0.00714 seconds
Time Before: 0.03323 seconds
Time After: 0.03372 seconds
Time Before: 0.03398 seconds
Time After: 0.03415 seconds
Time Before: 0.03503 seconds
Time After: 0.03779 seconds
Time Taken: 0.00276 seconds
Time Before: 0.03423 seconds
Time After: 0.04233 seconds
Time Taken: 0.00810 seconds
Time Before: 0.05421 seconds
Time After: 0.05459 seconds
Time Before: 0.05703 seconds
Time After: 0.05824 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05341 seconds
Time After: 0.05845 seconds
Time Taken: 0.00505 seconds
Memory After: 2,261.820 KB
Time Before: 0.08171 seconds
Time After: 0.08184 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.10431 seconds
Time After: 0.10552 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.12057 seconds
Time After: 0.12074 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.12417 seconds
Time After: 0.12566 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789072858, location = '/forums/private.php?do=newpm&explain=1&u=101534' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.14886 seconds
Time After: 0.14910 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
