Time Before: 0.00148 seconds
Time After: 0.00201 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00208 seconds
Time After: 0.00261 seconds
Time Before: 0.00281 seconds
Time After: 0.00291 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00350 seconds
Time After: 0.00593 seconds
Time Taken: 0.00243 seconds
Time Before: 0.00296 seconds
Time After: 0.00926 seconds
Time Taken: 0.00630 seconds
Time Before: 0.01108 seconds
Time After: 0.01138 seconds
Time Before: 0.01352 seconds
Time After: 0.01470 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01045 seconds
Time After: 0.01486 seconds
Time Taken: 0.00442 seconds
Memory After: 2,261.703 KB
Time Before: 0.01969 seconds
Time After: 0.01990 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02177 seconds
Time After: 0.02296 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.024582147598267
Time Before: 0.02575 seconds
Time After: 0.02586 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.02785 seconds
Time After: 0.02930 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=101545', badlocation = 1
Time Before: 0.04164 seconds
Time After: 0.04188 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.040754079818726 seconds with 9 queries, spending 0.0077474117279053 doing MySQL queries and 0.03300666809082 doing PHP things.
