Time Before: 0.00960 seconds
Time After: 0.01126 seconds
Time Taken: 0.00166 seconds
Time Before: 0.01136 seconds
Time After: 0.01183 seconds
Time Before: 0.01210 seconds
Time After: 0.01223 seconds
Time Before: 0.01308 seconds
Time After: 0.01576 seconds
Time Taken: 0.00268 seconds
Time Before: 0.01231 seconds
Time After: 0.01975 seconds
Time Taken: 0.00745 seconds
Time Before: 0.02410 seconds
Time After: 0.02430 seconds
Time Before: 0.02753 seconds
Time After: 0.02873 seconds
Time Before: 0.02343 seconds
Time After: 0.02896 seconds
Time Taken: 0.00553 seconds
Time Before: 0.04690 seconds
Time After: 0.04703 seconds
Time Before: 0.05374 seconds
Time After: 0.05499 seconds
Time Before: 0.06037 seconds
Time After: 0.06052 seconds
Time Before: 0.06292 seconds
Time After: 0.06435 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=10157', badlocation = 1 WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.07773 seconds
Time After: 0.07804 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
