Time Before: 0.01119 seconds
Time After: 0.01468 seconds
Time Taken: 0.00349 seconds
Time Before: 0.01475 seconds
Time After: 0.01523 seconds
Time Before: 0.01550 seconds
Time After: 0.01568 seconds
Time Before: 0.01644 seconds
Time After: 0.01850 seconds
Time Taken: 0.00206 seconds
Time Before: 0.01575 seconds
Time After: 0.02264 seconds
Time Taken: 0.00689 seconds
Time Before: 0.02942 seconds
Time After: 0.02983 seconds
Time Before: 0.03226 seconds
Time After: 0.03351 seconds
Time Before: 0.02873 seconds
Time After: 0.03372 seconds
Time Taken: 0.00499 seconds
Time Before: 0.05398 seconds
Time After: 0.05411 seconds
Time Before: 0.06811 seconds
Time After: 0.06936 seconds
Time Before: 0.07808 seconds
Time After: 0.07823 seconds
Time Before: 0.08056 seconds
Time After: 0.08204 seconds
UPDATE session SET lastactivity = 1789065033, location = '/forums/private.php?do=newpm&explain=1&u=101579' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.09888 seconds
Time After: 0.09916 seconds
