Time Before: 0.00181 seconds
Time After: 0.00249 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00256 seconds
Time After: 0.00308 seconds
Time Before: 0.00331 seconds
Time After: 0.00346 seconds
Time Before: 0.00431 seconds
Time After: 0.00668 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00355 seconds
Time After: 0.01069 seconds
Time Taken: 0.00715 seconds
Time Before: 0.01288 seconds
Time After: 0.01326 seconds
Time Before: 0.01566 seconds
Time After: 0.01684 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01222 seconds
Time After: 0.01708 seconds
Time Taken: 0.00486 seconds
Memory After: 2,261.703 KB
Time Before: 0.02431 seconds
Time After: 0.02466 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02726 seconds
Time After: 0.02853 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.03278 seconds
Time After: 0.03300 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03623 seconds
Time After: 0.03772 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101581' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05048 seconds
Time After: 0.05070 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
