Time Before: 0.00173 seconds
Time After: 0.00225 seconds
Time Before: 0.00235 seconds
Time After: 0.00283 seconds
Time Before: 0.00309 seconds
Time After: 0.00322 seconds
Time Before: 0.00404 seconds
Time After: 0.00676 seconds
Time Taken: 0.00272 seconds
Time Before: 0.00328 seconds
Time After: 0.01086 seconds
Time Taken: 0.00758 seconds
Time Before: 0.01271 seconds
Time After: 0.01313 seconds
Time Before: 0.01454 seconds
Time After: 0.01579 seconds
Time Before: 0.01201 seconds
Time After: 0.01603 seconds
Time Taken: 0.00402 seconds
Time Before: 0.02168 seconds
Time After: 0.02183 seconds
Time Before: 0.02371 seconds
Time After: 0.02493 seconds
Time Before: 0.02784 seconds
Time After: 0.02798 seconds
Time Before: 0.03008 seconds
Time After: 0.03152 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101592' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04472 seconds
Time After: 0.04499 seconds
