Time Before: 0.00213 seconds
Time After: 0.00296 seconds
Time Taken: 0.00083 seconds
Time Before: 0.00305 seconds
Time After: 0.00348 seconds
Time Before: 0.00371 seconds
Time After: 0.00382 seconds
Time Before: 0.00465 seconds
Time After: 0.00789 seconds
Time Taken: 0.00324 seconds
Time Before: 0.00390 seconds
Time After: 0.01305 seconds
Time Taken: 0.00915 seconds
Time Before: 0.01517 seconds
Time After: 0.01561 seconds
Time Before: 0.01825 seconds
Time After: 0.01969 seconds
Time Before: 0.01443 seconds
Time After: 0.01994 seconds
Time Taken: 0.00551 seconds
Time Before: 0.02567 seconds
Time After: 0.02582 seconds
Time Before: 0.02826 seconds
Time After: 0.02949 seconds
End call of global.php: 0.031525850296021
Time Before: 0.03285 seconds
Time After: 0.03300 seconds
Time Before: 0.03602 seconds
Time After: 0.03754 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=101593'
Time Before: 0.05192 seconds
Time After: 0.05218 seconds
Page generated in 0.050989866256714 seconds with 9 queries, spending 0.0089545249938965 doing MySQL queries and 0.042035341262817 doing PHP things.
