Time Before: 0.00140 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00261 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00293 seconds
Time After: 0.00306 seconds
Time Before: 0.00375 seconds
Time After: 0.00634 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00311 seconds
Time After: 0.00975 seconds
Time Taken: 0.00664 seconds
Time Before: 0.01213 seconds
Time After: 0.01249 seconds
Time Before: 0.01379 seconds
Time After: 0.01506 seconds
Time Before: 0.01147 seconds
Time After: 0.01523 seconds
Time Taken: 0.00376 seconds
Time Before: 0.02019 seconds
Time After: 0.02033 seconds
Time Before: 0.02253 seconds
Time After: 0.02387 seconds
Time Taken: 0.00134 seconds
Time Before: 0.02812 seconds
Time After: 0.02831 seconds
Time Before: 0.03149 seconds
Time After: 0.03295 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101597', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04705 seconds
Time After: 0.04730 seconds
