Time Before: 0.02639 seconds
Time After: 0.03502 seconds
Time Taken: 0.00863 seconds
Time Before: 0.03512 seconds
Time After: 0.03559 seconds
Time Before: 0.03581 seconds
Time After: 0.03594 seconds
Time Before: 0.03677 seconds
Time After: 0.03935 seconds
Time Taken: 0.00258 seconds
Time Before: 0.03600 seconds
Time After: 0.04344 seconds
Time Taken: 0.00744 seconds
Time Before: 0.05086 seconds
Time After: 0.05128 seconds
Time Before: 0.05450 seconds
Time After: 0.05569 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.05011 seconds
Time After: 0.05590 seconds
Time Taken: 0.00580 seconds
Memory After: 2,261.703 KB
Time Before: 0.08800 seconds
Time After: 0.08814 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.11194 seconds
Time After: 0.11318 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.12706 seconds
Time After: 0.12722 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.12978 seconds
Time After: 0.13124 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101607', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.15082 seconds
Time After: 0.15128 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
