Time Before: 0.03791 seconds
Time After: 0.04549 seconds
Time Taken: 0.00758 seconds
Time Before: 0.04559 seconds
Time After: 0.04608 seconds
Time Before: 0.04632 seconds
Time After: 0.04643 seconds
Time Before: 0.04705 seconds
Time After: 0.04922 seconds
Time Taken: 0.00217 seconds
Time Before: 0.04648 seconds
Time After: 0.05417 seconds
Time Taken: 0.00769 seconds
Time Before: 0.06567 seconds
Time After: 0.06598 seconds
Time Before: 0.06797 seconds
Time After: 0.06922 seconds
Time Before: 0.06495 seconds
Time After: 0.06946 seconds
Time Taken: 0.00451 seconds
Time Before: 0.11031 seconds
Time After: 0.11046 seconds
Time Before: 0.13565 seconds
Time After: 0.13692 seconds
Time Before: 0.14926 seconds
Time After: 0.14945 seconds
Time Before: 0.15161 seconds
Time After: 0.15307 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101618' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.17406 seconds
Time After: 0.17429 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
