Time Before: 0.00187 seconds
Time After: 0.00258 seconds
Time Taken: 0.00072 seconds
Time Before: 0.00265 seconds
Time After: 0.00312 seconds
Time Before: 0.00336 seconds
Time After: 0.00347 seconds
Time Before: 0.00413 seconds
Time After: 0.00657 seconds
Time Taken: 0.00244 seconds
Time Before: 0.00352 seconds
Time After: 0.01186 seconds
Time Taken: 0.00834 seconds
Time Before: 0.01478 seconds
Time After: 0.01516 seconds
Time Before: 0.01779 seconds
Time After: 0.02008 seconds
Time Taken: 0.00229 seconds
Time Before: 0.01408 seconds
Time After: 0.02031 seconds
Time Taken: 0.00622 seconds
Time Before: 0.02804 seconds
Time After: 0.02820 seconds
Time Before: 0.03203 seconds
Time After: 0.03328 seconds
Time Before: 0.03757 seconds
Time After: 0.03780 seconds
Time Before: 0.04039 seconds
Time After: 0.04194 seconds
Time Taken: 0.00155 seconds
UPDATE session SET lastactivity = 1783042073, location = '/forums/private.php?do=newpm&explain=1&u=101619', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.06085 seconds
Time After: 0.06117 seconds
