Time Before: 0.02501 seconds
Time After: 0.03176 seconds
Time Taken: 0.00675 seconds
Time Before: 0.03190 seconds
Time After: 0.03244 seconds
Time Taken: 0.00054 seconds
Time Before: 0.03273 seconds
Time After: 0.03288 seconds
Time Before: 0.03358 seconds
Time After: 0.03675 seconds
Time Taken: 0.00317 seconds
Time Before: 0.03293 seconds
Time After: 0.04229 seconds
Time Taken: 0.00936 seconds
Time Before: 0.05157 seconds
Time After: 0.05178 seconds
Time Before: 0.05438 seconds
Time After: 0.05618 seconds
Time Taken: 0.00180 seconds
Time Before: 0.05096 seconds
Time After: 0.05640 seconds
Time Taken: 0.00544 seconds
Time Before: 0.09510 seconds
Time After: 0.09530 seconds
Time Before: 0.11690 seconds
Time After: 0.11816 seconds
Time Before: 0.12969 seconds
Time After: 0.12988 seconds
Time Before: 0.13337 seconds
Time After: 0.13484 seconds
UPDATE session SET lastactivity = 1776613519, location = '/forums/private.php?do=newpm&explain=1&u=101638', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.15650 seconds
Time After: 0.15682 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
