Time Before: 0.01593 seconds
Time After: 0.02034 seconds
Time Taken: 0.00441 seconds
Time Before: 0.02046 seconds
Time After: 0.02102 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02126 seconds
Time After: 0.02138 seconds
Time Before: 0.02228 seconds
Time After: 0.02452 seconds
Time Taken: 0.00224 seconds
Time Before: 0.02146 seconds
Time After: 0.02844 seconds
Time Taken: 0.00698 seconds
Time Before: 0.03479 seconds
Time After: 0.03518 seconds
Time Before: 0.03685 seconds
Time After: 0.03808 seconds
Time Before: 0.03412 seconds
Time After: 0.03830 seconds
Time Taken: 0.00418 seconds
Time Before: 0.06435 seconds
Time After: 0.06452 seconds
Time Before: 0.07742 seconds
Time After: 0.07867 seconds
Time Before: 0.08712 seconds
Time After: 0.08730 seconds
Time Before: 0.09011 seconds
Time After: 0.09156 seconds
UPDATE session SET lastactivity = 1783090150, location = '/forums/private.php?do=newpm&explain=1&u=101641', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.10950 seconds
Time After: 0.10984 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
