Time Before: 0.00160 seconds
Time After: 0.00214 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00222 seconds
Time After: 0.00257 seconds
Time Before: 0.00275 seconds
Time After: 0.00287 seconds
Time Before: 0.00363 seconds
Time After: 0.00573 seconds
Time Taken: 0.00209 seconds
Time Before: 0.00291 seconds
Time After: 0.00910 seconds
Time Taken: 0.00619 seconds
Time Before: 0.01097 seconds
Time After: 0.01137 seconds
Time Before: 0.01367 seconds
Time After: 0.01486 seconds
Time Before: 0.01038 seconds
Time After: 0.01512 seconds
Time Taken: 0.00474 seconds
Time Before: 0.02223 seconds
Time After: 0.02238 seconds
Time Before: 0.02472 seconds
Time After: 0.02598 seconds
End call of global.php: 0.028480052947998
Time Before: 0.03004 seconds
Time After: 0.03021 seconds
Time Before: 0.03265 seconds
Time After: 0.03405 seconds
Time Taken: 0.00140 seconds
SET lastactivity = 1789140334, location = '/forums/private.php?do=newpm&explain=1&u=101648'
Time Before: 0.05008 seconds
Time After: 0.05039 seconds
Page generated in 0.048894166946411 seconds with 9 queries, spending 0.0074546337127686 doing MySQL queries and 0.041439533233643 doing PHP things.
