Time Before: 0.00685 seconds
Time After: 0.01013 seconds
Time Taken: 0.00328 seconds
Time Before: 0.01020 seconds
Time After: 0.01075 seconds
Time Taken: 0.00055 seconds
Time Before: 0.01102 seconds
Time After: 0.01120 seconds
Time Before: 0.01197 seconds
Time After: 0.01423 seconds
Time Taken: 0.00226 seconds
Time Before: 0.01127 seconds
Time After: 0.01822 seconds
Time Taken: 0.00696 seconds
Time Before: 0.02429 seconds
Time After: 0.02453 seconds
Time Before: 0.02600 seconds
Time After: 0.02721 seconds
Time Before: 0.02364 seconds
Time After: 0.02745 seconds
Time Taken: 0.00381 seconds
Time Before: 0.04154 seconds
Time After: 0.04172 seconds
Time Before: 0.05400 seconds
Time After: 0.05587 seconds
Time Taken: 0.00187 seconds
End call of global.php: 0.058114051818848
Time Before: 0.06623 seconds
Time After: 0.06645 seconds
Time Before: 0.06940 seconds
Time After: 0.07157 seconds
Time Taken: 0.00217 seconds
SET lastactivity = 1788987325, location = '/forums/private.php?do=newpm&explain=1&u=101659', badlocation = 1
Time Before: 0.09007 seconds
Time After: 0.09037 seconds
Page generated in 0.088782072067261 seconds with 9 queries, spending 0.0091798305511475 doing MySQL queries and 0.079602241516113 doing PHP things.
