Time Before: 0.02732 seconds
Time After: 0.03633 seconds
Time Taken: 0.00901 seconds
Time Before: 0.03642 seconds
Time After: 0.03685 seconds
Time Before: 0.03707 seconds
Time After: 0.03721 seconds
Time Before: 0.03796 seconds
Time After: 0.04079 seconds
Time Taken: 0.00283 seconds
Time Before: 0.03727 seconds
Time After: 0.04571 seconds
Time Taken: 0.00844 seconds
Time Before: 0.05293 seconds
Time After: 0.05340 seconds
Time Before: 0.05702 seconds
Time After: 0.05919 seconds
Time Taken: 0.00218 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.05216 seconds
Time After: 0.05942 seconds
Time Taken: 0.00726 seconds
Memory After: 2,261.703 KB
Time Before: 0.09770 seconds
Time After: 0.09805 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.11449 seconds
Time After: 0.11579 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.12892 seconds
Time After: 0.12914 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.13193 seconds
Time After: 0.13350 seconds
Time Taken: 0.00157 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101686', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.15308 seconds
Time After: 0.15340 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
