Time Before: 0.01751 seconds
Time After: 0.02512 seconds
Time Taken: 0.00761 seconds
Time Before: 0.02523 seconds
Time After: 0.02569 seconds
Time Before: 0.02595 seconds
Time After: 0.02611 seconds
Time Before: 0.02687 seconds
Time After: 0.03035 seconds
Time Taken: 0.00349 seconds
Time Before: 0.02618 seconds
Time After: 0.03443 seconds
Time Taken: 0.00825 seconds
Time Before: 0.04470 seconds
Time After: 0.04544 seconds
Time Taken: 0.00074 seconds
Time Before: 0.04845 seconds
Time After: 0.04971 seconds
Time Before: 0.04391 seconds
Time After: 0.04999 seconds
Time Taken: 0.00609 seconds
Time Before: 0.08731 seconds
Time After: 0.08744 seconds
Time Before: 0.10768 seconds
Time After: 0.10896 seconds
Time Before: 0.11965 seconds
Time After: 0.11981 seconds
Time Before: 0.12250 seconds
Time After: 0.12397 seconds
UPDATE session SET lastactivity = 1776645080, location = '/forums/private.php?do=newpm&explain=1&u=101704' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.14821 seconds
Time After: 0.14853 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
