Time Before: 0.01438 seconds
Time After: 0.01934 seconds
Time Taken: 0.00496 seconds
Time Before: 0.01944 seconds
Time After: 0.01986 seconds
Time Before: 0.02014 seconds
Time After: 0.02027 seconds
Time Before: 0.02123 seconds
Time After: 0.02344 seconds
Time Taken: 0.00222 seconds
Time Before: 0.02035 seconds
Time After: 0.02870 seconds
Time Taken: 0.00835 seconds
Time Before: 0.03372 seconds
Time After: 0.03412 seconds
Time Before: 0.03721 seconds
Time After: 0.03841 seconds
Time Before: 0.03300 seconds
Time After: 0.03865 seconds
Time Taken: 0.00565 seconds
Time Before: 0.06201 seconds
Time After: 0.06214 seconds
Time Before: 0.07184 seconds
Time After: 0.07305 seconds
Time Before: 0.08188 seconds
Time After: 0.08211 seconds
Time Before: 0.08487 seconds
Time After: 0.08629 seconds
UPDATE session SET lastactivity = 1783186566, location = '/forums/private.php?do=newpm&explain=1&u=101715' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.10409 seconds
Time After: 0.10438 seconds
Memory Before: 4,289.063 KB
Memory After: 4,289.289 KB
