Time Before: 0.00139 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00237 seconds
Time Before: 0.00259 seconds
Time After: 0.00277 seconds
Time Before: 0.00342 seconds
Time After: 0.00583 seconds
Time Taken: 0.00241 seconds
Time Before: 0.00282 seconds
Time After: 0.00928 seconds
Time Taken: 0.00646 seconds
Time Before: 0.01114 seconds
Time After: 0.01159 seconds
Time Before: 0.01400 seconds
Time After: 0.01524 seconds
Time Before: 0.01047 seconds
Time After: 0.01542 seconds
Time Taken: 0.00495 seconds
Time Before: 0.02103 seconds
Time After: 0.02117 seconds
Time Before: 0.02334 seconds
Time After: 0.02456 seconds
End call of global.php: 0.026548862457275
Time Before: 0.02782 seconds
Time After: 0.02795 seconds
Time Before: 0.03047 seconds
Time After: 0.03197 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=101720'
Time Before: 0.04483 seconds
Time After: 0.04508 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.043797969818115 seconds with 9 queries, spending 0.0079128742218018 doing MySQL queries and 0.035885095596313 doing PHP things.
